I don't know if I should do this since it is altering the 'factory' spec of my car. Where my tach should be there is a huge clock, I mean this is handy and all but doesn't give me much excuse for being late. Can I swap in the cluster from another model i.e. the 320?
More importantly, should I do it?
Swap instrument cluster..
- e21-Mark
Re: Swap instrument cluster..
Swap another cluster in and just put the original under your bed in case you ever want to re-fit it. Any e21 cluster will fit but you'll have to check what wires you need for the rev counter?
You need the rev counter for a 4 pot, 6 pot rev counters have something different electronically, can't remember what off top of my head!
I have two clusters in my pile of bits - one may have a 4 pot tacho in.
If your car is a 6 pot and I am confused, I think I have one of them too!
1982 Saphirblau Baur 325i
Cars all gone!
Cars all gone!
- e21-Mark
You're right Jim. Is it some resistor or something?
I'm getting flashbacks to a circuit diagram, there's an extra diode or something in one of them which converts 6 pulses (or 4) into what the tacho reads.
there's a thread somewhere on here about it, in the meantime I'll check what clusters I have!
Cars all gone!
Cars all gone!
Reck
Thanks drjim.
Does anyone know if the plugs are already there?
yes ! But you will need the button that fits in the dash below the clocks that is used to set the time! I changed a 4cylinder tach to run with 6 cylinder engine by swaping a resistor inside for one with a value 33% higher...edd..Reck wrote:Thanks drjim.![]()
e21 316 (1981) TRE702X.
yea, the thread your thinking of is that "just another m50 swap" done by that guy in europe.
