Headlights
- e21-Mark
Headlights
I am trying to replace the headlights on my TWR as the originals are lost/damaged. They were wired so that all 4 lamps worked as both dip & main but I'm unsure how? Does anyone else have any idea? Are there bulbs with dual filaments that would fit the BMW lights? Has anyone else got their headlights connected in this way?
- Jason_323i
Re: Headlights
I guess they just used h4 lamps in stock head lights and looped the wiring into both lamps
Jason
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
- E21meister
Re: Headlights
So it doesn't have high beams? i thought that was an MOT fail, or is that only if they're not working when fitted?
- e21-Mark
Re: Headlights
Yes, it has main beams, but from what I can find out it has the bulbs that contain twin filaments. One for dip and two for main beam.
Along these lines.
http://www.autobulbsdirect.co.uk/R414-1 ... -R414.html
Along these lines.
Mobster
Re: Headlights
As far as i know the 323iS was the only car that had this set up so if you want it done "properly" then prob best try and find someone who has one. However, as i say, i thought it was the 323iS that had this set up so my guess is that it was not on your car as standard. Another thing to perhaps note is that one of my M535i has this set up and i constantly have drivers from the opposite side flashing their beams at me as they think i have my main beam on. Annoying for me and them tbh.
- e21-Mark
Re: Headlights
The second owner told me that this is how the car came from TWR.
Mobster
Re: Headlights
......also, i am 99% certain that the cars that came with this as standard, the headlight lens (glass) is slightly different, i have seen it and it is very difficult to describe, but it has a lip all the way round the diameter of of the lens. From memory, it is only the outer lens that has this lip.
Re: Headlights
would the outer headlights be something like this
http://www.jaymic.com/shop/parts_02_pro ... p?grp=02EL
e21 316 (1981) TRE702X.
Re: Headlights
Don,t laugh! But are the headlights fitted to some jcb,s the same fitting but with h4 bulbs fitted. Like some of the lights in the link below
http://shop.ebay.co.uk/?_from=R40&_trks ... Categories
