Replace TCA bushes - Is this a job I can do at home?
Can anyone post a step by step guide please?
TCA bush replacement
- e21-Mark
- Jason_323i
Re: TCA bush replacement
After tears of practice I cold do them in about an hour leaving the track contrail arms on the car, the first attempt was few days, what car are that for as polybush would be better and easier to fit on the track car
Jason
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
- e21-Mark
They're for my orange car Jason. I'm guessing if they took you a couple of days the first time, I would be better getting someone else to do them?
A pair of new complete TCA's are available locally for £100 unless anyone knows somewhere cheaper?
- Jason_323i
Mark in your new facilities it should be okay, my first attempts i was just not aggressive/equipped to do it fast
my method
car secure on ramps with front wheels
Loop a ratchet strap between the ends of the anti roll bar
drop of the anti roll bar front mounts
anti roll bar rear bolts
pull the arb off using ratchet strap to compress it
then i had a 32mm impact socket which is the perfect size for a drift and a 4lb hammer
2-3 wacks a side and the old bushes are our
Use the dremel to clean up the bush housing, and wipe of grease
then i used a long 10m bolt with some plate steel washers and an large impact socket
basically bolt, washer, then impact socket acting like a cup on the back of the tca with the bolt going through the bush housing, then slide the bush onto the bolt fit another big washer and nut and tighten till the bush is seated in the housing
then refit the arb using the ratchet strap to get it back in
Jason
my method
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
- e21-Mark
Thanks Jason. Between you and the YouTube vids I've just watched, I reckon I should be able to manage. Famous last words. Anyway, I'm going to have a go tomorrow. Thanks again.
markomarko
- Newbee
jason just off the subject. The picture of those triple webbers and manifold are they of your car if so where do I get that set up ?
- PeteK
- My E21(s): 1979 323i Euro
It's not too hard. We got the bar out with a couple of mates and the bushes off with a bit of hammering.
Pete K
'79 323i (for good times)
'81 M535i (for collecting)
'75 520i (track machine)
'03 320i (for commuting)
'97 Laser
'97 Laser
