murrans 325i.
- DrGonzoPOW
Re: murrans 325i.
The war with the holes rages on. Is the end in sight ?
Whats with the love hearts John!?
Wakefield Hellfire
Re: murrans 325i.
its a car for drifting! not looking mint. it'll do for now.MRE21 wrote:That's looking really good Murran! What will you do with the paint work on the rear quarter? Will you blend it in yourself? or a full respray?
it'll probably wait till either my mate tom can do it or..... till the boss goes on holiday at work and then it can be done under the radar.
Re: murrans 325i.
those are some stickers i found in the house. we're getting there. theres still the holes round the back lights. hole in the b post by the rear window. also i hole in the inner wing on the o/s/f
Re: murrans 325i.
done the holes in the back panel around the lights. it was fun. one hole at a time! done 4 today. had to rebuild the lamp surround on the n/s thanks to this hole being much worse when i took the lamp out....
repair looks good tho! pics later!
ive brokenified the plastic trim inbetween the back lights too. doh! might just run without but have that bit black insted?
Re: murrans 325i.
I'd like to see how you tackeld this repair. I recognize that rust...
Some E21's look great without the black trim between the lights. Otherwise it's a cheap part anyway.
Re: murrans 325i.
tbh, it could have done with a back panel welding in it, if yours is like mine thats your best bet for a lasting repair.
but being that mines never going to be a mint car, gets used for drifting etc..... and i cant afford a new back panel. i just chopped it out the grotty bits made some patches and welded them in. then a touch of filler to tidy it up..... its not hard to do. for me anyway lol.
Re: murrans 325i.
couple of pictchurez.
other tiny holes in the back panel still to do....
rather annoying ones around the lock....
how do you take the lock out, i looked at it for 10 seconds but couldnt work it out? plus i was guna leave it for another day anyway.
might actually paint the back panel black above bumper line, i kinda like it!
ive also thrown the rubbish black plastic bit between the lights in the bin as its pointless, broken and useless.
- e21-Mark
Re: murrans 325i.
iirc the inside part of the lock unscrews. It's like a threaded barrel. Awkward to get at though. I think that's right anyway?
Re: murrans 325i.
and yes, theres a little teddy bear wearing a scarf, hanging under the back of my car.
Re: murrans 325i.
Undo the two bolts holding the latch bit in and the lock is a lot more accessible. There's a big plastic nut that screws onto the barrel to hold it in place. Piece of piss to remove, slightly more fiddly to get back in but if I can do it, you definitely can!
1982 Saphirblau Baur 325i
Cars all gone!
Cars all gone!
Re: murrans 325i.
well ive fitted two s/h tyres from the scrappers on the rear today.... rear tyres are disposeable to me, im damned if im buying new ones!
also a quick oil and filter change at work.
up to drgonzo's tomorrow to help finish his. wish us luck!
Re: murrans 325i.
John
I am working on finding a trimmer to stick canvas to my targa panel and windscreen surround, once that's done I have no excuse not to get the Baur on the road, apart from the fact that there seem to be loads of vacuum pipe attachments on the inlet that aren't connected to anything. I also have your post-it which says "small pipe from back of head to manifold" I am now paranoid that I have connected a water pipe to a vacuum inlet or something equally daft and will not be able to try starting it until someone who knows what should go where looks at the car. I will need you to stop helping Dave for a day or so.
Also I have lots of steelies with serviceable tryes on, including some that have been painted blue whilst attached to the Baur - you are welcome to melt them!
Jim
Jim
Cars all gone!
Cars all gone!
Re: murrans 325i.
jim i'll reply to this in the morning when im less drunk. have been to the pub and need to sleep!
hnag on....
small pipe from back of the head? that can only be one of the pipes to the throttle body crank case breather heater pipes?
http://www.realoem.com/bmw/showparts.do ... g=11&fg=35
no 19. it goes to the the connection nearest the baulkhead on the n/s of the head.
theres only one vac pipe.... to the fuel pressure reg?
have you sorted the wiring out? im having to use my car to check daves wiring cus you have my diagrams? look thru them whatevar says c101 on them that seems important...... etc.
all the perm lives/earths into the motronic looms shold be self explanatory.....
hnag on....
- DrGonzoPOW
Re: murrans 325i.
Meeeoow!! Haha. Alas Mr Murran has now given me all the help i need. Much praise indeed.drjim wrote: I will need you to stop helping Dave for a day or so.
Will have to have a meet sometime in the near future for all the Northern monkeys
Wakefield Hellfire
Re: murrans 325i.
cheers for the beers dave, should last me a couple of weeks!
