Unleaded?
Millar
Unleaded?
Post by Millar »
How can i check if my 82' 320/6 has been converted to run on unleaded?
murran
Re: Unleaded?
Post by murran »
it'll be fine, bmw's already had harded valve seats along time before other manufacterers......... if you had a 1980 mg metro it'd be a different story.
Millar
Re: Unleaded?
Post by Millar »
happy days, it'll be kept running on morrisons finest then haha. lets here the story then?
pjksutherland
Re: Unleaded?
Post by pjksutherland »
Wait a minute - does that mean I can run my 323i on bog standard unleaded without the Castrol valvemaster additive I keep buying at £15.00 per bottle??
Jason_323i
Re: Unleaded?
Post by Jason_323i »
Yeah, any alloy head car already has hardened steel valve seats. May just need to swing the dizzy a bit to alter the timming (minimal)
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Re: Unleaded?
pjksutherland wrote:Wait a minute - does that mean I can run my 323i on bog standard unleaded without the Castrol valvemaster additive I keep buying at £15.00 per bottle??
Yes, but use superunleaded. 2002's don't need additive either. They've run unleaded in Germany for donkeys years.
Silver Surfer
Re: Unleaded?
Post by Silver Surfer »
What running normal unleaded cause any issues?
Re: Unleaded?
Might get a bit of pinking with regular.
murran
Re: Unleaded?
Post by murran »
maybe retard the timing 2-5 degrees? to be safe.
Silver Surfer
Re: Unleaded?
Good point. Prob better to run super anyway just never really thought of it.
Rushfan1
Re: Unleaded?
Post by Rushfan1 »
I always run on premium fuel as I find it prevents the knocking. Shell V Power is wondeful stuff.
mcjjordan
My E21(s): Uk 1980 316 m52
Re: Unleaded?
Post by mcjjordan »
back in the 90s i ran both 323 and 320 on unleaded and it burnt the valves out in both :(
better top be safe than sorry, id be using the addative anyway
polov8
Re: Unleaded?
Post by polov8 »
It's more likely the car was running lean and/or the ignition was too advanced, it's not like a 320 or 323 is a highly strung powerhouse.
Andy
Re: Unleaded?
That would be my guess as well. After running several K kms on leaded in the 1980's even the older engines have no issues running on unleaded.
