my 78 320i, any advice?
redagain
Post by redagain »
I purchased a low mileage 78 E21 that was in good running order when stored 8 years ago. So far I have drained tank, new gas , new plugs, new wires, new rotor, new distributor cap ,new condensor, new points, new fuel filter, checked for vacuum leaks and replaced some lines. When I fire it up it idles like a dream but wants to die when you give it gas. It wont take any throttle input. occasionally I can get it to rev up a bit. This is my first E21, any advice on what to try next? Thanks
Re: my 78 320i, any advice?
fuel pump?
redagain
Post by redagain »
was hoping it would be cheaper...but maybe..guess its down to that or dirty injectors.
sskoda
Post by sskoda »
idling well but dying when throttled usually points to an air leak. You've maybe missed one?
redagain
Post by redagain »
I'll check tomorrow...thanks
redagain
Post by redagain »
Well , I really went over it, no vacuum leaks that I can find. A few lines in question replaced. Still dies when you give it gas. Fuel pump. Im ready for the $250 bite if need be. Thanks
Considering that price, it might be good to do a check on pressure and production first, even though I do not have any reference, anyone?
you could fit a fuel pressure gauge and double check?
redagain
Post by redagain »
Well, I put in a new fuel pump and that wasnt the problem. Pulled the injectors and cleaned them. Put them back with new seals. Runs the best it has since I bought it. Actually drove it around the block. At about 2500 rpm's it flattens out and the car starts to shake and shutter no matter what gear your in. So it idles great, drives, but at 2500 rpms it hits a wall so to speak. Ive done everything and replaced everything I can think of. Stumped..
Tato
My E21(s): 1980 E21 316/1 manual
Post by Tato »
Consume much gasoline?
Maybe these link will help you.
(K-Jetronic manual)
http://forums.bimmerforums.com/forum/sh ... ?t=1106768
(K-Jetronic tip)
http://www.bmwfaq.com/f12/regularcion-d ... ndex3.html
(in spanish, maybe can help you using google translator)
Read these in particularly
http://www.auto-solve.com/mech_inj.htm
Regards,
1980 316/1
redagain
Post by redagain »
havent been able to drive it enough to know..
