auto to manual gearbox swap?is it possable?
tom bailey
- Newbee
I am new to the forum and have just placed a wanted ad up on here, I was wondering if it is possable to convert the 21 from a automatic to manual easily? I know another pedal would need to be added and other bits buts has it been done before? just curious so I can be more open minded on cars I get offered .Any help appreciated:)
Re: auto to manual gearbox swap?is it possable?
You need a clutch pedal and cylinder, the gearbox/clutch, flywheel, linkage/lever, bit of wiring under the dash where there's a start inhibitor relay to bypass, reservoir hose and some sort of bracket to fit the reservoir to. Done it on my Baur, not too hard.
Jim
Jim
1982 Saphirblau Baur 325i
Cars all gone!
Cars all gone!
I certainly hope it's possible I've just this weekend gone had the engine and auto box out of mine to convert to manual..
Take a look at this for a little insight. http://forums.bimmerforums.com/forum/sh ... p?t=949479
It may take me a couple of weekends but mainly it's just time consuming and dirty...
Still it's clean up time, sort a couple of rusty patches, then start put it back together as a manual. Looking forward to the test drive...
Hope this helps...
Hope this helps...
