Brake master cylinder
Dan323i
Post by Dan323i »
My car has just failed on a leaking master cylinder. Any idea where I can get one? Is it shared with any other BMWs such as an E30? Thanks in advance!
Jacko
Re: Brake master cylinder
Post by Jacko »
Yeah it will be, i've got one at the unit not doing anything but it's Nas's so you'll need to ask him for it. :)
Dan323i
Post by Dan323i »
Heck, I've just given the garage the OK to order a genuine one from Germany! Ah well.
Jacko
Post by Jacko »
New is always best anyway.
Dan323i
Post by Dan323i »
You'd think so – the garage got one sent over from Germany and it's no good! Been sat on the shelf for years presumably and the seals are all hardened and no longer seal properly. They've taken it apart, soaked all the bits in fluid overnight and reassembled it and it still is not working properly. Maybe I should drop your mate Nas a line...
olivewoo
Post by olivewoo »
You could get new seals from biggred.co.uk
jimbob
Post by jimbob »
uused a master cylinder seal kit from biggred this week briliant service but the kit had the wrong reservoir
rubbers i ended up using the ones from a 98 e39 :screwy
E36 328i Daily driver
E36 328i Touring
olivewoo
Post by olivewoo »
Yes I had same problem, rung them and they matched them up and exchanged them...
How did you know the use the e39 ones and where did you get them?
jimbob
Post by jimbob »
got them from my e39 just lucky they fit
it was thanks to your post i found biggred too otherwise i would have had to get a new master :thumbsup
E36 328i Touring
olivewoo
Post by olivewoo »
No Problem. Glad it helped (almost).
I would have hoped they'd of sorted the kits by now, but at least they sorted it out when I contacted them..
