m50 engine swap
mcjjordan
My E21(s): Uk 1980 316 m52
Re: m50 engine swap
Post by mcjjordan »
yh i know about the speedo issue
but what car does this 6 speed box come from? as some are expensive but some are cheap
mcjjordan
Re: m50 engine swap
Post by mcjjordan »
what about power steering?
with the heavier engine am i thinking its gonna be an issue not having it?
how easy is it to steer when going sideways?
Mihajlo
My E21(s): 1982 315swap323i
Re: m50 engine swap
Post by Mihajlo »
it is very easy to steer when going sideways...
wheel is turning all by itself. I didn't have any problems with it on drift day.
initial steer is normal and when tail starts to slide, you just let go steering wheel (little by little) and then grab the wheel when the car is reached angle you like or need....
it is messy to explain but it is very simple as is.
Re: m50 engine swap
IIRC, (inc accessories)
an m10 weighs about 80? or 90kg
The m52 weighs 125kg
m50 engine weighs about 180kg
cant remember what the m20 weighs
Re: m50 engine swap
About 120-125kgs iirc
mcjjordan
Re: m50 engine swap
Post by mcjjordan »
anyone got any images that show the difference between the 4 and 6 cylinder front cross members?
Re: m50 engine swap
Real oem ?
polov8
Re: m50 engine swap
Post by polov8 »
These are early (top) and later (bottom) style 6 cyl crossmembers
And the lower one in this pic is a 4 cyl version (the upper is E36)
Andy
mcjjordan
Re: m50 engine swap
Post by mcjjordan »
ah i see so they are same shape (later ones) just the mounts that can be cut off and new ones welded in anyway .
so no need to find a 6 cylinder - just weld up the 4 i already have
mcjjordan
Re: m50 engine swap
Post by mcjjordan »
is there a way of converting from rear drums to discs?
apart from sourcing 323 arms , how do the calipers mount?
cant seem to find a close up picture.
Mihajlo
Re: m50 engine swap
Post by Mihajlo »
Re: m50 engine swap
mcjjordan
Re: m50 engine swap
Post by mcjjordan »
Vw calipers?
I have a pair of those around here somewhere....
mcjjordan
Re: m50 engine swap
Post by mcjjordan »
what about a fuel filter?
do you just rely on the filter in with fuel pump or just an inline filter in engine bay?
i see original 323 had a big metal cylindrical filter .
i assume it had to be metal due to pressure?
Re: m50 engine swap
Ah glad your thinking of details :)
3 bar pressure and I use an inline filter.
