e21 type 1 to 2 conversion questions
Scoob
My E21(s): eu 80's 320
Post by Scoob »
Hi there everybody,
i have got a few things i want to sort out i have a e21 type 2 320 6 cil with a rotten shell and i want to use all the parts to put on a e21 type 1 316 1.6 4cyl
what parts of the type 2 doesnt or does fit to the type 1 shell so i am referring for example to the doors hood interior undercarrriege etc
i hope you guys can help me out because im not getting any smarter from the rest of inet and google+wiki
cheers from holland!
arshad76
Re: e21 type 1 to 2 conversion questions
Post by arshad76 »
Hello and welcome! I'm actually doing something similar between having a BMW E3 series 1 upgraded to a series 2. Anyway, the advice I was given was to cross reference part numbers from something like realoem.com between the twp models and that will be the most accurate comparison.
From what I know though, here are some of the following differences between the series 1 and two cars.
Door mirrors: series 1 chrome, series 2 plastic and electric
Front valance, shallower on a series 1
Rear light lenses different
Dashboard has different switchgear between models
Indicator stalks differ
Gearknob is a screw in type on a series 1 as opposed to a push type on a series 2
Interior seat trim differs
Sure someone can add to the list.
UK Moderator
Scoob
Post by Scoob »
now that is some perfect information thanks a million!
i wonder if there is anything else.....
so all the sheetmetal is the same to?
anyway thanks!
arshad76
Post by arshad76 »
No problem :) I think the sheet metal, apart from the front valance should be the same (I'll wait for someone to correct me though). Sheet metal is the same as far as I know though.
UK Moderator
johne21
Post by johne21 »
Front seat chassis mounting points differ, door window mechanism is different but doors are interchangeable.
1976 e21 320i A4 Alpina #1755
johne21
Post by johne21 »
Mk 1 seat belts connect to straps bolted to tunnel, Mk 2 fasten into side of seat.
the front suspension is different on the series 1. but are interchangeable with the later type. you also have a different braking servo system. The heating and ventilation controls are different.
Eddie.
My E21(s): [O==[][]==O]
Post by Eddie. »
Subframe, ARB and control arms are all different too.
luke
Post by luke »
Radiator support panel is different too - not sure whether this effects whether the shallower series 1 front valance fits.
It is a better looking valance though with the bigger vents in it.
But back to the initioal Q, if he has a good 4 cil chassis and can use a 320/6 as a donor, he may be able to swap many parts still I guess?!
