Engine Bay Sound Deadening
Eddie.
My E21(s): [O==[][]==O]
Post by Eddie. »
Right, I need a replacement sound deadening.
I've just rang BMW Wilmslow and they're saying it's NLA and none of the dealers in the UK are holding any stock (which is no suprise)
Does anyone know of anyone doing an aftermarket one, or does anyone have one in good condition.
Part number is 51481852348.
Cheers.
problemchild75
Re: Engine Bay Sound Deadening
Post by problemchild75 »
Are the early and late ones the same ?
Eddie.
Post by Eddie. »
I don't think so no, but maybe I could modify one?
This is a common problem because indeed BMW does not have it anymore. (even in Germany).
mr edd
Post by mr edd »
Early to late if different It might only be the cut outs for the brackets that the brake servos bolt to on the bulkhead that are different ...
e21 316 (1981) TRE702X.
3771489
Post by 3771489 »
Late one won't fit early models. That "radius" in picture is different. Body after 8/77 have more space for m20 and longer "radius".
Eddie.
Post by Eddie. »
I'm making the assumption that I'll not run into trouble with the engine swap with regards to that radius?
No, it'll be fine. You can always cut the rubber deadening pad too. (or ditch it all together?)
I ended up sacking the sound deadening off altogether. It does actually do its job pretty well. my car is a bit more noisy now, so I was going to take all the carpets out and then line the bulkhead from inside the car with some of that fancy dynamat stuff.
Eddie.
Post by Eddie. »
Yeah, I want the car to be quiet in all honesty, not too fussed about finished weight or anything.
Good news on the body taking the engine and box as well, had me worried for a bit!
