Problemchild75s 1983 safari m52
QuiqueUy
My E21(s): '81 320/6 manual
Re: Problemchild75s 1983 safari m52
Post by QuiqueUy »
really nice build , readed the 19 pages lol.. keep it going and people not serious are everywhere , it's strange that someone that sell an engine do that but well , somtimes happens! keep it going sir!
problemchild75
Post by problemchild75 »
Thanks. It's all sorted now LLLLLLLLLOOOOOOOOLLLL. they have blown the pirts out and spun the engine and say it will be fine. And sending it back to me. I flipped big time. These guys are f*** comedians. Needless to say after a few phone calls I got a refund and no doubt some poor soul will get that engine sent to them.
On a plus note welder turned up on time worked quickly, did a awesome job , tided up and went. I will post pics tomorrow. If only all tradesmen worked that way.
If they said it's fine, it must be true. :screwy
I told you my welder dude was awesome. Glad something went right.
problemchild75
From the department of solid work...
croma_man
My E21(s): '83 EU 327i
Post by croma_man »
I see you are using the tilter lift...how is it?
problemchild75
If you don't like lying under the car on your back the tilter is awesome. I wouldn't be without it.
That's some damn fine welding right there!
You just need a nice, shiny billet mount. ;) I may even have some left?
problemchild75
The other diff mount will be removed. I will just need a single bush bolting downwards from the boot floor.
mcjjordan
My E21(s): Uk 1980 316 m52
Post by mcjjordan »
hows the new diff coming on?
did you have to alter the drive shafts?
I can answer as I run the same setup -
he copied me and fitted an e12 diff. the beauty of this diff is that you can use your existing drive shafts and prop.
Eddie.
My E21(s): [O==[][]==O]
Post by Eddie. »
Can you not with an E21 LSD?....
if your name is Problemchild then no not really as its not strong enough. hence the e12.
Eddie.
Post by Eddie. »
Ah so the issue is the E21 LSD can't take the power/torque from the M52?
