Anti roll bar brace
Desmos
My E21(s): 81 320i manual
Anti roll bar brace
Post by Desmos »
Hey all.
Am I right in thinking there's benefits to be made from additional bracing across the front ARB?
I'm sure I read somewhere that Alpina offered this. Does anyone have any images as looking to fabricate one.
Thanks in advance.
Re: Anti roll bar brace
Not too expensive through our website's main sponsor either:
http://www.motorsportparts.nl/bmw-e21/o ... ssis-stang
Desmos
Post by Desmos »
Perfect thank you.
Are there benefits to be had?
Bigger if you don't have a strut brace but it does stiffen things up anyhow making it feel more rigid, solid, less sensitive to deep tracks, more stable turn in.
drjim
Post by drjim »
Where does that attach to?
1982 Saphirblau Baur 325i
Cars all gone!
Front sway bar mounts, just using longer bolts.
drjim
Post by drjim »
Does that make a difference? Surely swaybar mounts are joined together by the front end metalwork so fairly solid. I get the concept of the strut brace, but this seems a bit different.
Cars all gone!
croma_man
My E21(s): '83 EU 327i
Post by croma_man »
IF the front suspension would be made like it is on a E30, this wouldn't be necessary.
I have it on my E21, as I already had a strut brace and was looking for a even more solid front, this was the best thing to do, and you have an additional guard if you are driving low.
Yup, the whole E21 front is floppy so everything helps
Desmos
Post by Desmos »
Knocked this up:
Surprisingly good mod. Much less tram lining and bump steer seems reduced. Not bad for free :boogie
croma_man
Post by croma_man »
change the bushes if you want to revolutionize the driving in the E21
Desmos
Post by Desmos »
On the list bud.
Trying to source some upgraded versions...if anyone knows a linky?
Eddie.
My E21(s): [O==[][]==O]
Post by Eddie. »
I've had a problem with my ARB upgraded bushes, they won't fit! No matter how much grease I use, they're not going on!
The front ARB stiffening bar looks good though.
Jason_323i
Post by Jason_323i »
Good mod with a stripped down shell you can flex the front chassis rails by hand
It is the arb to control arm bushes you want to upgrade and there are 2 versions
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
+1 with all above haha, nice upgrade installed right away, should do a crash course on welding myself some day
