'76 316 manual gearbox identification
e21_lyf
My E21(s): M42'd 1976 316
Post by e21_lyf »
Hi all,
Please may I have some help from anyone in the know, as to the ident of this transmission?
Cant see 'Getrag' on it, or much else!
E21noob
My E21(s): SOLD
Re: '76 316 manual gearbox identification
Post by E21noob »
Most certainly a 4 speed getrag. Not sure why it has 232 and not 242 markings but as far as I know they are not to be trusted anyway.
e21_lyf
Post by e21_lyf »
struggling to figure it out myself to be honest! a lot of the ident markers seem to point to things that aren't there. Perhaps its got something to do with it being a v.early e21? No idea. Bit crap as I've offered the box out for sale in various places, now I have no idea what it is!
ChrisW
Post by ChrisW »
Pretty sure thats a getrag 232 4 speed gearbox for a BMW 2002.
e21_lyf
Post by e21_lyf »
Ok,I have spoken to the prior owner.
She is 100% on the car being 5 speed and it working with no issues (yes I did ask her if she meant 5 forward gears AND reverse :loll ).
However, since the internet verdict is that it is 4 speed, and in order to answer many questions - I will take the end plate off IAW the BMW IPC, photograph the shaft & synchro's etc, replace with cork gasket / Thiokol, put fresh oil in and post pics.
That should answer questions on condition/gears/condition.
So you have the gearbox with you? I'd certainly try the shift pattern (if you do not attach the regular gear lever but just stick a screw driver through the shifter axle please note the pattern is mirrored so beware not to identify reverse as 5th gear.
What am I saying this? The latest series of E21 M10 5-speeds does not have the extension but then it could still be a 5 speed. Never knew but we found out recently with a Dutch member's gearbox.
Post by 3771489 »
Early e21 4-speed. Not 2002,clutch slave cylinder is different. Some parts are "same casting" 232 vs. 242 and thats why those both have 232 castingmarks.
Latest m10/m20 5-speed 240-Getrag have bigger "ass" than 242.
245,240,242 in pic.
Once again thanks for the valuable information!
e21_lyf
Post by e21_lyf »
agreed, that is excellent! Thank-you for your help there
