Hi All
It's been sometime (years) since I last posted. Hopefully a quick Q – are sill skins available for the E21? My searches have come up fruitless. If not how much labour do you estimate to replace the entire sills both sides? I'm wanting to get the car in best shape before committing to a respray.
Cheers
Andrew
Sill Skins
Re: Sill Skins
Yes, at Walloth and Nesch, they have some pretty great reproductions, good quality. New inner sills are reproduced bij BMW, so you can get those at the dealer
dr3wid
- Newbee
- My E21(s): 316 '83 Hennarot Red
Re: Sill Skins
Thanks Uwbuurman – sorry daft question are the outer sills = sill skin?
Re: Sill Skins
Well, no daft questions at all. Just beware, the skin implies that it is the outside, so the part that you can see below the door, when closed. The sill consists of an innerpart, that holds the electric wire harness on the right side, that holds the side of the carpet and the doorrubbers. Outersill is the part as described.
Beware, in the old days they had coverplates, that went over the sill, when rotten. You dont want that, you want the perfect fitting replacement part.
Outside:
https://www.wallothnesch.com/aussenschw ... 04-03.html
Inside
https://www.wallothnesch.com/innenschwe ... 04-11.html
Also take al look at www.bmwfans.info, just give in your chassisnumber and start scrolling through the exploded views.
Outside:
Inside
dr3wid
- Newbee
Re: Sill Skins
Great thanks for the help Uwbuurman!
