My car 318 76 model converting to 323i
Re: My car 318 76 model converting to 323i
Grandeeeeeeeeeeeee!!!!! e adesso gaaaaaaaasssssssssss
- Atle_323i
- My E21(s): 76 EU 318
After 4000 km the head gasket gave up. Not sure yet the reason for it failing. I had an minor overheat accident after a thermostat failure. Not sure if that is part of the reason.
So I´ve bought a 731 head, which my friend has been preparing for me, checking it with the BMW manual for clearings, etc. The head is in good condition, probably low milage.
The head is now going to the machine shop to be milled off.
Then I hope it will be change of head before winter and storage.
A few pictures from the head I bought.
- Atle_323i
A minor update.
My head is being prepared for installation, the 200 head is off. My friend has checked the head for leak, and it´s all good.
I´m abit exited for the 731 head, I wonder if I will notice the difference in power compared to the 200 head.
Hopefully I get my car ready for 1.May, as this is start of the veteran car season. 1.May is big happening in Norway, all sorts of cars is gathering at different locations all over Norway, to mark the start of spring.
Happy Easter everyone
Checking for leak.
Checking for leak.
Ben ritrovato, le camme sono standard ?
- Sierpien
- My E21(s): C1 Turbo Alpina tribute, 316 Sepiabraun
- Facebook page: https://www.instagram.com/fedecx5aa/
Hello! great work!! Getting the K jet working fine is a labor of love! keep the good work.
Alex von Falkenhausen
- Atle_323i
Had some issues after the coldstart injector stopped adding extra fuel, then engine began to run very poorly. Couldn´t figure it out at the first.
But after some searching around, I found the rubber suction hood, wasn´t properly fitted, so I had vacuum leak, so the baffle didn´t lift enough to give proper amount of fuel.
After sorting this out, the engine ran good.
I had the radiator replaced with a new original BMW, because the other I had from Behr, has so much rust inside. I think it doesn´t work properly, and that the cooling is very poor. Since I´m having trouble keeping the temp at normal. I made an override switch inside the car to force the fan run at low speed to give the radiator more cooling. So I hope this new one sort out that issue.
There is a minor engine sound change from the 200 head, with the 731 head, and the engine seems to respond abit better on reving.
So now all there is the left before taking it out for a drive is to check and do the valve clearance adjustment, and turn the idle speed down abit, seems to be around 1500 now.
I´m so ready for a proper road test now
Wow proper progress, and looks good once more!
- Atle_323i
Yeah, nice to finally being able to drive the car again.
I have a leak problem around the water pumpe, either it´s leaking through the gasket, or the pump spindel is leaking. Can´t figure out yet where the leak is from, need to take off the timing cover, and have a look when idling, and see where it´s coming from.
So still not 100%, but I can drive the car, just need to add abit of water now and then until I have a new gasket and pump delivered.
Always something after a big job, pity if you have to do work twice... let us know what you find!
- Atle_323i
I made it to 1. of May, official start of the car/bike season. But not without problems.
The engine runs to rich, so I thought I should check the system and control pressure of the k-jet.
I managed to get 5 bar on system pressuere and 3.2 bar on control pressure on warm engine.
So everything is where it should be.
After leaving the car for the night, I checked again, then things started to look bad. I only managed to get 3 bar system pressure and 1.2 bar control pressure. This just happened over the night, without doing anything to the car.
I checked the pump flow at the return of distributor, and managed to get 9.2dl after 30 second on running the pump, so I´m 0.8 dl off what it should be. So I´m abit out of idea, what could be wrong.
All parts were new last season, fuel pump, fuel accumulator, fuel lines, distributor and wur overhauled last year, all the injectors are 1 year old.
Only part I haven´t replaced is the cold start injector.
So if anyone got an idea what I could check, let me know.
Pictures at home before leaving to the 1. of May meeting.
Looking fabulous, still in love with these tail pipes! As for the problems, what brand of fuel pump did you fit?
