Well and quick update is in order. My clutch is sorted and better than ever with a really good pedal and absolutely no play in the system.
As it was dry I decided to pop out the speaker and trim on the drivers side and see if I could spot where the leak might be? I even poured a little bit of water down the sunroof drain hole at the front. I couldn't see any obvious leak though, so I simply made sure that everything seemed to be in the right place. I also made sure that the plastic pipe wasn't being trapped by the speaker.
Sorry about the picture quality but the camera on my phone didn't like the glare from the orange paintwork.
Speaker and cover re-fitted
Blaupunkt London which came free with some second-hand speakers. My satnav is getting on a bit which is why it's the size of a 1970's portable tv.
I needed a set of HT leads and I discovered a small motor factors store just down the road who hooked me up with these 8mm silicon jobbies in red.
£30 for the complete set which I think is bloody good value.
So, hopefully I can start to enjoy my e21 again although I'm still dreading it raining. Apart from fitting the HT leads the next job on the list is to sort out the scruffy Recaros. I have something on it's way from California that I hope will provide a solution so I'm keeping a look out for the UPS man.
