Alpina A4
m3gaz
- My E21(s): looking
Alpina A4
Forgive my Alpina ignorance,but i've just met a bloke who tells me he has a 1978 E21 Alpina A4 in his lock up.As is the norm he said he was "going to get round to doing it up"'.I'm gonna try and get a look at it sometime soon.Anything i should know to prove its kosha?
- e21-Mark
- e21-Mark
OKM 226P was a genuine A4s/3 - A4s being the same engine as the injected ALPINA 2002 and the 3 denotes it being a 3 series. If its genuine it should also be a pre 1978 car as they switched to modifying 323i's then.
Jimmy probably knows more but I think there were about 120 earl cars converted but how many made it to the UK I have no idea. There's a book available - which you can take a look at on Sunday if you like? - by James Taylor.
- e21-Mark
Alpina a4
Hi m3gaz,
In addition to retrobeemers comments there should also be matching chassis/engine numbers between +3780001+ and +3781950+ (rhd 320i/4
manufactured 11/75-8/77) with Alpina engine number +A4/3****+ next to cyl block number. Also four digit Alpina head number below the water inlet manifold. The Alpina engine number should correlate with the 9 page
Alpina spec sheet detailing modifications undertaken. Other considerations
are wheels, spoiler, clocks, dog-leg box, vented discs and maybe long range fuel tank in boot.
hope that helps
regards
johne21
(owner of the black one)
hope that helps
regards
johne21
http://i990.photobucket.com/albums/af24 ... A40086.jpg
check this out
check this out
- e21-Mark
m3gaz reminded me about Retro Car mag and showed me the e21 feature in this months.
Alpina and the influence of Chinese under-bonnet bling!
November issue
http://www.retrocarsmag.com/
November issue
- e21-Mark
