replacing fuel lines
cdavie2002
Post by cdavie2002 »
Has anyone done this before?
Iv got an advisory on the mot that the fuel lines are corroded.
Do you just go to dealership?
Buy and bend pipe yourself?
Get flexible braided hose?
Chris
1982 320/6 (breaker)
1975 3.0 csi
1974 3.0 csi (donor)
2003 E46
you can get rubber or use 8mm copper pipe (i think).
Is there a fuel return line on a 316 tank?
cdavie2002
ahh i dunno! Still trying to figure out whats on mine.
Chris
1975 3.0 csi
2003 E46
Lars-Nord
Post by Lars-Nord »
cdavie2002 wrote:ahh i dunno! Still trying to figure out whats on mine.
I guess you just got one line. No problem to make this out of bending copper.
81 e21 323i polaris
drjim
Post by drjim »
316 should just have a single line.
roll of 8mm copper pipe from Wickes/B&Q etc or ebay is all you need. Probably have to take the tanks off to get it fitted properly.
I did the ones on the slug before fitting the tanks.
Clips will be rotten, so much soaking in wd40 type stuff then careful removal, buy new ones or if you are building a race car with no interior use nylon P-clips and pop rivets.
it's a job best done on a ramp, so I think I'd just get a little man at a garage to do it.
Jim
1982 Saphirblau Baur 325i
Cars all gone!
Madhatter
Post by Madhatter »
by the time you buy the tools for bending and flaring the ends, then the amount of pipe you go through learning how to use things, the hours it will take you in the end, can pay a professional to do it for similar price and be done within an hour.
tommi_e21
Post by tommi_e21 »
why would you need to flare the end of a fuel line????? its not like brake lines and just use sockets to bend decent raduis.
if you cant be arsed to take tank out just use a longer bit of rubber hose and poke it down.
and there is only 1 line on a carb car, only injection uses a return line
Ideally, you should put a slight flare on the end of a fuel line although I never have. Just make sure the rubber section covers the metal pipe by at least a couple of inches and use new jubilee clips. If it were a high pressure fuel system you'd need more but the mechanical fuel pump on a 316 should be fine.
if you want to flare the pipe a big phillips screwdriver on the of the pipe couple of turns job done. ghetto mechanics ftw!
tommi_e21
Post by tommi_e21 »
he means a little rased section, easy to flare out its just flaring back in to get the little rise in the circumfrance for the pipe to grip onto
Jason_323i
Post by Jason_323i »
Domestic copper is not the best for fuel line as vibrations make it work harden & go brittle
Just buy the line from BMW, removing the clips like Drjim says is a pain, just drill them out and use P Clips to hold new fuel line. Also you need to drop the tank to fit the lines
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Madhatter
Post by Madhatter »
austin25uk wrote:why would you need to flare the end of a fuel line????? its not like brake lines and just use sockets to bend decent raduis.
what stops hoses sliding down fuel line when simply held on by a hose clamp?
Friction I guess? I think that's why it's only suggested for low pressure fuel systems with mechanical fuel pumps?
Madhatter
Post by Madhatter »
just vibrations are enough for them to slide off. Even carbed fittings and connections have flared ends.
tommi_e21
Post by tommi_e21 »
use 2 jubilee clips then, job done :)
