lowering e21 320i '79
hanse21
Post by hanse21 »
I'm keen to lower my e21 at both the rear and front. I have standard 13' bmw wheels (the ones that look like little alpinas). It has standard springs in it which i am planning to cut with a spring compressor. I am wondering will i need to replace the shocks with anything different? Also how much would i have to cut to drop it about two inches? Or is 2 inches to far? Cheers all look forward to your replies, hanse21.
Re: lowering e21 320i '79
So long as you don't go too low your old shocks should be OK. It depends on their condition though too. If I were you I would start with a single coil as it's far easier to take more off than put back on again.
Millar
Post by Millar »
i'm looking at doing the same eventually, i did a bit of research and everyone basically said exactly what mark just told you, a coil at a time.
tommi_e21
Post by tommi_e21 »
just cut 2 coils off all round, usually does the job. dont expext it to pass an MOT though as your rear springs will prob dislocate on full extension and MOT men dont like cable tie spring holders
Audi 50 RS
