I acquired an M-sport steering wheel (off an E30 I think). It goes onto the splines ok but then my indicators will not self-cancel, unless I remove the little spacer on the column shaft itself (pictures here:)
http://www.slickattire.com/images/spacer1.jpg
http://www.slickattire.com/images/spacer2.jpg
But with the spacer removed the steering wheel doesn't seat itself properly and wobbles about on the column, not very safe!
Does anyone know where I could get hold of a slimmer one, or a friendly lathe-owner who might be able to knock one up for me?
Dan
Steering column spacer
Re: Steering column spacer
What happens if you put the spacer on the other side of the boss?
