Sticking accelerator
andy205
Post by andy205 »
Hi, started car up today after standing for months and the accelerator is sticking, whays the first thing i should be looking at, thanks
murran
Re: Sticking accelerator
Post by murran »
might be the cable, if you disconnect it at the throttle body/carb end and feed some engine oil down it, then work it up and down etc. also there a spindle thru the baulkhead that maybe stiff?
petroscf
My E21(s): '77 EU 316 manual
Post by petroscf »
When I first drove the car with the weber, my accelerator was sticking several times as well.
Problem was solved for good with some WD40 on the weber at the choke puller (is that hte right english term?Sorry,if you don't understand I'll try to explain this better)
/oo=00=oo\
E21 Forever
andy205
Post by andy205 »
Thanks , will try above on weekend.
