Hey guys wanted to hear your recommendation regarding tires for my E21.
I currently have the FPS basketweaves but also have a set of the Mahle-BBS ones that need some work. The car has a 2.7 stroker with the solex 4 a 1 and this my
curren tires 185/70/13 just don't do the trick.
I was thinking about going 205/60/13 I've seen that the cars look a little lower with those tyres and they look really nice. Thing is would the 205 be a problem with
those rims? And will it suffice to handle the torque of a 2.7 on the back?
Another concern is I got mechanical steering and it's already very hard to use I bet 205's won't make it easier.
Thoughts?
Tire recommendation
Kpeters
Tire recommendation
My 1981 Kastanien Rot 327 [url]http://www.bmwe21.net/forum/viewtopic.php?t=789[/url]
2002 71"
2002 71"
- e21-Mark
- E21 Master
Re: Tire recommendation
I ran 205/60x13's back in the day. No rubbing etc. I run 195's up front, with no pas & a quick-rack.
Kpeters
Great do you think 205's in the front would create any rubbing? I like to have all tires that same size so I can rotate them side to side back to front etc. If necessary.e21-Mark wrote:I ran 205/60x13's back in the day. No rubbing etc. I run 195's up front, with no pas & a quick-rack.
2002 71"
2002 71"
- e21-Mark
- E21 Master
I think you'll be fine with 13's
Kpeters
Great thanks don't wanna be messing up my speedo readings. Going 60/205 messes it up for just 1 km/h.e21-Mark wrote:I think you'll be fine with 13's
2002 71"
2002 71"
