Hazard problem.....not the usual one(i think)
sleeperviva
Post by sleeperviva »
Evening gents
I encountered the usual problem of the hazard light switch failing to pop back in so went ahead and just bought a new one from the main stealers. Went to fit it just now and i now have no hazards at all......not even a chirp :goodnight all i get is the clock dimming a bit when the button is pressed.
Im confused! Had a gander at the haynes book of lies but that hasnt really helped....could i just be unlucky and bought a duff switch? or is there a dedicated hazard relay hiding somewhere? all i can find is the indicator relay under the column
Any thoughts???
Steve :stupidme
'83 BMW E21 316 aka The Daily (poss going M10 turbo)
'74 Vauxhall Viva Twin-Cam
'91 Ford Thunderbird 3.8SC
Other assorted rubbish also
Re: Hazard problem.....not the usual one(i think)
They all use the same relay afaik. Indicators working? Then perhaps a bad switch indeed?
sleeperviva
Indicators are indeed functioning as they should
Does the hazard circuit somehow share any wiring with the clock? The dimming of the clock isnt what id expect of a duff switch
