Removing outer sills.
Eddie.
My E21(s): [O==[][]==O]
Post by Eddie. »
I want to remove the outer sills on my E21, but I can't quite seem to see how they come off?
I'm probably just having one of those moments, but do they come off? If so, how?!?
I've highlighted the section that I mean in the photo below:
Cheers.
Re: Removing outer sills.
Only using an angle grinder mate
Eddie.
Post by Eddie. »
Thought as much :(
Do they need to come off for someone to do some welding work around the jacking point?
cobbler2u
My E21(s): 323i baur
323i special
328 sport
325i
Post by cobbler2u »
No need to do sills if jacking points need doing.
Outer sills run from front to back, dut as the go past the door, than de run BEHIND the sidepanel. Take a look in my topic around page 31 and further. You can see how they are taken of an put on the car.
New outersills can be bougt at Walloth&Nesch, not at the dealers anymore. Be carefull with the inner sills, those are of the market...
