battery advice
Irish_chris
My E21(s): 81 318, 83 316t
battery advice
Post by Irish_chris »
ok so the battery in my e21 is pretty flat so i took the brand new battery i had in my e30 and tried to turn the car over and the starter just 'clicked'
is this the battery's fault?
johne21
Re: battery advice
Post by johne21 »
check for bad earths
1976 e21 320i A4 Alpina #1755
Re: battery advice
Bad ground cables in the engine bay indeed, engine to chassis on intake side and I believe head to firewall exhaust side. Also, do a turning session, you'll get used to that being an E21 owner: corroded contacts may cause fuses to fail or at least no let through enough current. Give your fuses a few turns to clean up, check relays. In the end, it could be bad wiring to the starter but I'd check in this order...
