Am I right in assuming this special washer goes on the nut side of the control arm/wishbone with the rubber ring facing the control arm?
ARB fitting
- AndyBaur
- My E21(s): 1983 320/6 Baur 5-speed (now gone)
ARB fitting
When I pulled off my anti roll bar I failed to notice that one of the two large washers at each end had a rubber ring around the perimeter of one face.
AndyS
Re: ARB fitting
Correct, that's where they could cause clunks hitting the control arm.
