323 rear end set up (swap)
Irish_chris
My E21(s): 81 318, 83 316t
Post by Irish_chris »
can i fit rear discs etc without having to change trailing arms?
drjim
Re: 323 rear end set up (swap)
Post by drjim »
Yes if you make your own adaptor brackets and fit calipers with an integral handbrake. Did it on the slug using A3/Golf calipers and standard E21 discs. Need suitable handbrake cables and of course flexi hoses/pipes made up to fit.
1982 Saphirblau Baur 325i
Cars all gone!
Irish_chris
sorry wasnt clear
i can buy a 323 rear end with calipers etc but my current trailing arms have custom brackets welded on for my suspension so was hoping the rest couldd be fitted onto my current trailing arms
drjim
Post by drjim »
Trailing arms are the bit that's different. I think the tabs for the 323 arb are on the other subframe anyway.
You need to fit the suspension mounting bits on the 323i trailing arms, or as I say custom brakets/VAG calipers.
Get your welder out lad!
Cars all gone!
Irish_chris
drjim wrote:Trailing arms are the bit that's different. I think the tabs for the 323 arb are on the other subframe anyway.
cheers
i think ill buy the setup anyway and figure something out!
