Sticky Brake Pedal
BAD323
My E21(s): 81 AUS 323i Manual
Sticky Brake Pedal
Post by BAD323 »
Hi, My brake pedal wont return all the way up, I have to put my toes under the pedal to lift it, otherwise the brakes stay on and even then they wont fully release. My vacuum seems to be working well no brake fluid leaks, I have replaced pads, Rotors. The only thing is the car has been sitting around for 4 months. Hope to get some answers. Thanks,,,,,.
healeyneil
Re: Sticky Brake Pedal
Post by healeyneil »
one of the pivots on the long rod from the pedal to the m/c had seized on mine, producing the same problem. strip and clean and grease sorted it
mcjjordan
My E21(s): Uk 1980 316 m52
Post by mcjjordan »
healeyneil wrote:one of the pivots on the long rod from the pedal to the m/c had seized on mine, producing the same problem. strip and clean and grease sorted it
same here push pedal until it stays down then undo bolts until it springs back into life
BAD323
Post by BAD323 »
Thanks, I also walked around the car and felt each Rim and found that it was extra hot which I believe that the front drivers side caliper is also sticking. I will do what you said about the linkage and pull apart the Caliper. Many thanks ( BAD 323 )
