M60 into a e21
Jameslc
My E21(s): 78 320i Manual
M60 into a e21
Post by Jameslc »
Hi Guys
Thinking about doing a M60B40 swap into an e21.Has anyone done this swap? if so is it still an enjoyable drive? like is that too much power for a e21?
Cheers James
polov8
Re: M60 into a e21
Post by polov8 »
Andy
Jameslc
Re: M60 into a e21
Post by Jameslc »
that's awesome!
Jameslc
Re: M60 into a e21
Post by Jameslc »
obviously still drivable,just scared it will want to slide everywhere :P
polov8
Re: M60 into a e21
Post by polov8 »
Fat tyres and an LSD are your friends I'd think!
Andy
croma_man
My E21(s): '83 EU 327i
Re: M60 into a e21
Post by croma_man »
done in our country too :mrgreen:
Re: M60 into a e21
Custom engine mounts.
X5 exhaust manifolds
Brake bias pedal box (floor mount)
And you will be needing a decent rear diff / driveshafts
Lowering blocks for front anti roll bar mounts.
I reckon you won't need to space frame it and it might just fit.
Re: M60 into a e21
croma_man wrote:Image
Love it!!!
polov8
Re: M60 into a e21
Post by polov8 »
Bollocks! I was hoping you'd HAVE to spaceframe the front to make it fit, but judging by that pic, it fits just fine! And there's an E39 540i in my local scappy too......
Now I have evil, and expensive plans forming. Thanks Croma_man. :(
Andy
croma_man
Re: M60 into a e21
Post by croma_man »
no problem mate, I'm used to make sh** happen :wha :wha :wha
Jason_323i
Re: M60 into a e21
Post by Jason_323i »
To be a geek it's been done loads as the m20 was called the m60 when it was first out in the e21
but about 10 years it was done in the states
http://forums.bimmerforums.com/forum/sh ... conversion
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Jameslc
Re: M60 into a e21
Post by Jameslc »
Got to love them trumpets,I did drop a m60 in a scrappy e21 to have a look at space and it fits.....just :p.
NAS80: I wasn't planning on running the sway bar,just coil overs with support rods going to the sway bar mounts.or is it better to try and fit the sway bar in ?
croma_man
Re: M60 into a e21
Post by croma_man »
as the sway bar and the strut bar, you'll need both to get the front to go where you want, I had big trouble with my M20 engine which is not so heavy as the M60, after fitting the good stuff,car handles, before it was all over the place.
polov8
Re: M60 into a e21
Post by polov8 »
BMW 340i hmmmmmmmmmmmmmmmm
Andy
Jameslc
Re: M60 into a e21
Post by Jameslc »
croma_man wrote:as the sway bar and the strut bar, you'll need both to get the front to go where you want, I had big trouble with my M20 engine which is not so heavy as the M60, after fitting the good stuff,car handles, before it was all over the place.
ok,spacers sound the easiest way to make the swaybar fit with the sump being in the way.or modify the sump at the front
