Grounding when relocating battery to the trunk
l3v4rt
My E21(s): '80 316 manual - Alpinweiss
Post by l3v4rt »
Hello everybody!
I'm working on my engine bay (respray) as it's going to get a new engine soon and to make more space,look more sharp and get better weight destribution I'm thinking of relocating the battery to the trunk/boot. Now I decited to get the positive pole to engine bay via interor (under the floor mat) but I'm having troubles to figure out where to put the grounding. I've seen photos on internet where people just bolt it to the rear wheel well but is there a better spot and is this safe? How about the wall betweeen the boot and rear seats? Do you have any advices about picking the spot and battery relocation related (my first time).
Thanks!
splitty456
My E21(s): '79 320/6 S54 Project
Re: Grounding when relocating battery to the trunk
Post by splitty456 »
Doesn't really matter where the grounding point is, the key thing is to remove the paint to make a good electrical contact.
But also make sure it's bolted down well - either weld a captive nut behind or place it somewhere you can get a nylock on the back of the bolt.
healeyneil
Post by healeyneil »
I welded a stud in- on the wheel arch, just because it suited the cable run. More important is making sure the +ve cable can't chafe anywhere
l3v4rt
Post by l3v4rt »
Thank you for your help guys, what kind of cable do you recommend? What size?
healeyneil
I used 170 amp stuff, bought on eBay
Mihajlo
My E21(s): 1982 315swap323i
Post by Mihajlo »
I used just an ordinary welding cable you can buy. no idea on size.
make sure you connect it well.
