Font End Overhaul
e21paddy
My E21(s): 320/6 1981
Font End Overhaul
Post by e21paddy »
Hello all,
I’ve recently had a steering rack reconditioned, bought a new fluid filter and bought a new PS pump (second hand). I also have some new springs and shocks for upfront, and have decided to change all bushings while I’m under it to totally refresh the front.
Before I set into it, is there any other parts I should change while I’m under there. Or any tips for undertaking this job. It seems pretty easy but I’ve been fooled before.
Thanks
Re: Font End Overhaul
Yeah, don't forget topbearings on the coils, those are the ones that have the 3 bolts in the shocktower, under the bonnet.
And replace the rubber mounts on the front swaybar.
e21paddy
Post by e21paddy »
I have Bilstein shocks and coils, is there any special adaptor needed? Found that bearing. 50 quid a pop yowza!
I have ordered Powerflex bushing for up front.
Its only that the nut that goes on top of the strut is different for Billies, usually you get them with the shocks
Yup, just undo them and put the nut back.
e21paddy
Post by e21paddy »
I’ll assess the top end bearing, see if it’s in bad nick and replace!
