My E21 turbo photo shoot
craga
RESPECT
Post by craga »
Respect!!!God work.I m interested in the turbo upgrade you have done.
What turbo did you put on,and what fuel injection upgrades have you done do to the turbo upgrade.I m in converting my own car to turbo so I would be grateful on all information I can get my hands on.Tnanks in advance...
Nils
Post by Nils »
Jeroen wrote:Pure E21 porn, great work and great pics, thanks mate!
Look out for the underside of your desk, now... 8)
Nils.
BMW E36 320iA coupé (1992)
jrcook320
Re: RESPECT
Post by jrcook320 »
craga wrote:Respect!!!God work.I m interested in the turbo upgrade you have done.
Here's my turbo setup:
Dinan turbo manifold (it was a rough casting, I had it machined for a T25 flange because it was too small for a T3)
Garrett T25, 60 trim, .80 AR, internal waste gate (from an S13 nissan silvia sr20det)
ebay 12" front mount intercooler
Hallman pro manual boost controller
DSM (eagle talon, plymouth laser) blow off valve
divorced port stainless dump pipe for sr20det
2.5" straight through exaust with side exit
Fuel/ignition system:
Volvo 240 turbo fuel distributor
Volvo 240t boost enriching warm up regulator
Volvo 240t boost retard ignition canister
Porsche 924 turbo (931) air flow meter
VW MK1 stainless fuel lines
Those are the only real mods I did to the fuel system. The stock e21 fuel pump will supply enough for at least 220hp (Jeff Beyer in CA can attest to this with his 2.8L 323i). The volvo fuel distributor is said to top out at 220 hp, but I have to proof of this. I used the Porsche air flow meter because it's downdraft rather than up draft and the outlet was in a perfect location for where I wanted to mount things. The mounting brackets are of course custom.
The volvo 240 turbo WUR has a boost port and a vacuum port. The vacuum port leans the mixture under vacuum and the boost port enriches the mixture under boost. There is of course a check valve on the vacuum port to block boost.
The Volvo 240 turbo ignition canister is a much larger dual port canister that also has a vacuum and a boost port. The boost port retards ignition under boost.
I did modify my WUR to make the control pressures adjustable, but so far haven't had to mess with it. I have more info on that if you want. Once I got the car running all I had to do was fine tune the mixture setting and it has been running great.
| '81 320i Turbo | T25, 931 CIS, 250hp, 13.92@100mph | jrcook320.e21legion.net |
craga
..other modifications?
Post by craga »
...on how much bost is the turbo set on?Engine modifications?
MikeG
Post by MikeG »
Great work and good photos.
Mike
Mcinek
My E21(s): '80 BMW 323i
Post by Mcinek »
Graet work, really great work and with the 323i exhaust it's goona be perfect!!!!!!!!!!!!!!!!!!!! Thanks for sharing.
BMW "Freude am Fahren"
Marcin
jrcook320
Re: ..other modifications?
Post by jrcook320 »
craga wrote:...on how much bost is the turbo set on?Engine modifications?
It's a 2.0L with flat top pistons with a 1.8 head. This gives me 7.9:1 CR. The head is ported/polished with a 280 cam. Motor also has a I-J crank scraper, TEP 13 lb lightened flywheel, electric cooling fan, and e12 65mm throttle body.
Fuel system now consists of mercedes benz 6.9L injectors, porcshe 924 turbo air flow meter and fuel distributor. It's boosting at 14 psi and making about 240-250 hp.
Mcinek wrote: Graet work, really great work and with the 323i exhaust it's goona be perfect!!!!!!!!!!!!!!!!!!!!
Finished:
nice! 8)
very nice car!!!
MadMax
Post by MadMax »
Bloody amazing. I am VERY jealous!
HAQUE
Post by HAQUE »
Thats amazing !!!!!!!!!!
Im lost for words
Haque :shock:
Haque
jirky
Post by jirky »
It's perfect :) Verry nice work!
BMW E21 3.16 Alpinweiss (Dailycar)
Infiniti FX 35 (Fun!)
ulises
Post by ulises »
Hi
Nice car
Congratulations :D
Andriuz
Post by Andriuz »
I love it...
That is a dream car...
In love whit e21
