1978 323i S50 Propan New update 2017!
Sierpien
Post by Sierpien »
Sierpien wrote:
Here`s a better picture of the original Hartge down force.
hey propan can you make a good photo of this?
Alex von Falkenhausen
Propan
My E21(s): 78' 323i
Post by Propan »
Sure. They will come tonight.
Sierpien
Post by Sierpien »
Propan wrote:Sure. They will come tonight.
OKey my friend, i will wait for you !!!!!
Propan
My E21(s): 78' 323i
Post by Propan »
Sent you an e-mail serpien.
Propan
My E21(s): 78' 323i
Post by Propan »
I have changed my plans about the engine.
It will not be a m20 turbo but a S50B32 M Power.
With a new intake manifold,cams og port&polish on the head it will be around 340-350 hp-thats more than enough.
I dont have the time any longer for turbo cars.
Too mutch garage spending time and less driving.
With the S50 it will be a nice sleeper and also a hell of a car on trackdays.
Imagine 8600 rpm on the S50...
Propan
My E21(s): 78' 323i
Post by Propan »
The engine is ready.
I have made 1 engine mount,doing the other now.
The engine in a m3e30 earlier.
hadrian
Post by hadrian »
:shock:
Highest posting Melbournite
Propan
My E21(s): 78' 323i
Post by Propan »
I just received my last parts today and could start mount the engine.
This days fitting was just to adjust the engine mount i have made to get the engine right where i will have it,and it`s getting even 15mm lower i think.
But i think it will be quite nice, I love the look of the M Power engines and the carbon airbox now,and really cant wait hearing this beast starts up :wink:
I have fitted it right where i want it now,and the engine is coming out again tomorrow to fit the gearbox and making it fit to the car.
I must cut and rebuilt the gearboxtunnel on the car to fit the 6 gear ZF.
I also get my new Alpina B6 radiator tomorrow and will try it on, so i can order the fan i must have. I also get a new dashboard.
Propan
My E21(s): 78' 323i
Post by Propan »
The gearbox almost fit now,need to mount the engine&gear once again to make sure before i weld all together again.
I have had engine&gear in and out of the car 5 times today..
Met another problem today,when i mounted the engine first time and adjusted angles and such,i had a power steering gear on...
Today i changed it to mechanical steering gear,and that was a lot bigger..
But I cut away some of the oil sump pan-problem solved.
I also lowered the engine another 16mm today,now it can`t be any lower without rebuild the hole oil pan or change it to drysump...
Either way i`m going to shorten the pan in the sump,it sticks to low to the ground,need to have i 35mm higher up.
In case anyone wonder-it is a M50 e34 oil pan and oil pick up-the e36 pan does not fit in e21/e30. The S50B32 engine also have two oil pick ups original in the e36,one in front and one in back.
I now have to short in the oil pick up together with the sump.
The Alpina radiator and dash still didden`t show up :cry:
misza
Post by misza »
fantastic job, i cant wait when u will end this project, can u tell me what sizes this well are? this is bbs? u say rear is 16/9?
sory for my english
Propan
My E21(s): 78' 323i
Post by Propan »
The rims on the car right now it not the bbs.
It is ATE 7,5x15 et13
The BBS RS i`m going to use later is 8x16 et 15 in front and 9x16 et 0.
Mcinek
My E21(s): '80 BMW 323i
Post by Mcinek »
Cant imagine how fast this e21 will be.
BMW "Freude am Fahren"
Marcin
XGiWiTHA323i
I like the rims...
Post by XGiWiTHA323i »
Got 'em on my 323i :D
Never argue with a moron...They will drag you down to their level and beat you with experience!
RR
Post by RR »
That's going to be a real beast 8)
Propan
My E21(s): 78' 323i
Post by Propan »
I has not been too many ours in the garasje,but some parts are bought in and the geartunnel is rebuild soon,took it from an E30.
Starting to happening things theese days.
