The gearbox almost fit now,need to mount the engine&gear once again to make sure before i weld all together again.
I have had engine&gear in and out of the car 5 times today..
Met another problem today,when i mounted the engine first time and adjusted angles and such,i had a power steering gear on...
Today i changed it to mechanical steering gear,and that was a lot bigger..
But I cut away some of the oil sump pan-problem solved.
I also lowered the engine another 16mm today,now it can`t be any lower without rebuild the hole oil pan or change it to drysump...
Either way i`m going to shorten the pan in the sump,it sticks to low to the ground,need to have i 35mm higher up.
In case anyone wonder-it is a M50 e34 oil pan and oil pick up-the e36 pan does not fit in e21/e30. The S50B32 engine also have two oil pick ups original in the e36,one in front and one in back.
I now have to short in the oil pick up together with the sump.
The Alpina radiator and dash still didden`t show up
