318i Baur TC1
- Jekyll66
Hi Peter, Yes it is working, but yesterday i find a problem in the relay for the fuelpump. so that the valve for coldstarting do not inject at first. ......So i think i am on the right way....wait a fue days.....Peter V. wrote:Hey Stephan,
is the fuelpump working, maybe a dum question, it maybe only circulate the fuel through the retour line and so does not generate enough pressure for the injectors.
Gr Peter
Thanks....
greetings Stephan
Completely storie of restoring TC1: http://3er-foren.de/showthread.php?tid=7965
[url=http://www.baur-tc1.de][img]http://i25.tinypic.com/2wrhrht.png[/img][/url]
Okey Stephan,
Surely you wil get it running. Please take the time for it so you wil not get frustated.
By the way, my 323i Baur is home now. After a quick look it needs a lott of work.
Gr Peter
Gr Peter
Hey Stephan,
I have just read your german forum and the problem you had with the grounding of the coolingblock of your ignitionmodule is the same problem which i had with my BAUR. That was why i needed the help of the ANWB (ADAC).
The engine just stopped running because it had no spark.
Gr Peter
Gr Peter
- Jekyll66
Hey Peter...Peter V. wrote:Hey Stephan,
Gr Peter
Thaks for informatin......
So i hope, the engine will work
Greetings
- Jekyll66
Hi,
a lot of time is gone....and many works is done.....
At first: The engine is not workung at time. I still wait for the k-jetronic, wich was out of order.....
In the last month i was rebuildung the body:
...... greetings
Stephan
...... greetings
Stephan
- Sierpien
- My E21(s): C1 Turbo Alpina tribute, 316 Sepiabraun
- Facebook page: https://www.instagram.com/fedecx5aa/
Good Work!!!
Alex von Falkenhausen
Hey Stephan,
Looks great again. I'm sorry to hear that you are still waiting on the k-jet unit. But progress is coming for sure.
I have been following your and Markus topics on the german site also and I must say, you both are perfect examples how a restauration must be.
Will you congratulate Markus with the fact that his engine is running now
Keep up the good work and hope to see you and the car in real live sometime.
Greetings Peter V.
Greetings Peter V.
- e21-Mark
